venapp file name
Posted: Mon Mar 29, 2010 5:30 am
by lynchyml
*.1vcd
*.2vcd
these files cann't be open by the "venapp"button?
Posted: Mon Mar 29, 2010 5:31 am
by lynchyml
and where are they from?
[Edited on 3-29-2010 by lynchyml]
Posted: Mon Mar 29, 2010 7:31 am
by Lee Jones
They are backup files created automatically by Vensim.
Go to the menu tools>options and the "startup" tab to specify where you would like backup files to be created if you don't want them clogging your model directory
Lee
Posted: Tue Mar 30, 2010 10:06 am
by lynchyml
thank you !
can I use these backup files to get the original files?
because the origihnal files get lost
[Edited on 3-31-2010 by lynchyml]
Posted: Wed Mar 31, 2010 9:50 am
by bob@vensim.com
Just rename the .2mdl file to have extension .mdl (.2vmf to .vmf) and so on and you can then use them.
Posted: Thu Apr 01, 2010 4:49 am
by lynchyml
it works,thank you!
but there are many Unrecognizable Code?
Posted: Thu Apr 01, 2010 9:32 am
by bob@vensim.com
My best guess is that the venapp source is using a different character encoding than expected. By default Vensim uses UTF8 but order versions would use the local encoding. Try Models>Convert Charset and then select as the originating encoding Chinese, Simplified and as the output UTF8 to see if that works.
Posted: Sat Apr 03, 2010 2:17 am
by lynchyml
it works
thank you very much!
[Edited on 4-3-2010 by lynchyml]
