interpolation of excel data
tbs14
Post by tbs14 »
I have a variable 'scheduled production' for an annual production schedule that is made up using Excel data using the Get Xls data command. Then I have another function that is defined as IF THEN ELSE(price>production cost,production ahead,scheduled production). However at the time steps where the Excel data is missing, the software interpolates the value. Is there any way I can stop this because I would like to use the actual data only.
TQ
Search the help system for "Data equations" you will need to use one of these to do what you want.
Use either :LOOK FORWARD: or :HOLD BACKWARD: in the equation for the data as in
my data :LOOK FORWARD: := GET XLS DATA...
You can also use the :RAW: pattern in your data, and then test for existence of data with IF THEN ELSE( myData = :NA:, ...
tbs14
Post by tbs14 »
Thanks for the feedback. I will try them out:)
