Connect Venapp to the model
I built my Venapp screen using the example, but how can I connect it to my models?
Not sure exactly what you mean by not showing your variables, but if your graphs are blank the cause may be that you haven't loaded a dataset (MENU>LOAD_RUN or SPECIAL>LOADRUN) or started a synthesim simulation. Can you describe your problem more fully, or post some code?
.vgd format is for custom graphs, which you can load via SPECIAL>READCUSTOM (but you don't normally need to do this if your custom graphs are in your model file).
LOADMODEL takes a model in .mdl, vmf, vpm, or vpa format (see the online help, DSS reference supplement, chapter 5).
