Dear All,
I am just wondering if there is a way of using functions in VENSIM to obtain a max or Min value of a variable info over the simulation period. The only way i think of now is to export the simulation values in excel and then use a max function in excel to get the max and or Min value. but this is a bit tiring and i want to know if it is possible to do this in VENSIM
Kind regards,
Vishah
a function to obtain the Maximum or Minimum value over a sim
min max
joined a model that does the job.
You can too use the sample if true function if your version allows you to use it.
[Edited on 21-6-2010 by LAUJJL]
- minmax.mdl
- (2.72 KiB) Downloaded 367 times
