Error Function in External Function
yobiman
Post by yobiman »
I am trying to write a simple external function in venext.c to calculate the error function. I have added #include math.h in the declarations and tryed to use the erf() function. When I do this I get a compile error.
Would appreciate any assistance with this
Phil
What is the compile error?
yobiman
Post by yobiman »
The error that I am getting is..
Error 7 error LNK2019: unresolved external symbol _erf referenced in function _ERF venext.obj venext6
Many thanks
Phil
You are missing the lib file that contains erf. Search google for the documentation for erf and see what library you need to include when linking.
Hope this helps.
yobiman
Post by yobiman »
You're right I think that is the problem.. Looks like the easiest solution is to use a standard approximation
many thanks for your help
Phil
If you can just add the .lib file to the linker options it should be fine.
You could also take a look at
http://social.msdn.microsoft.com/Forums ... c36e98d718
yobiman
Post by yobiman »
Many thanks!
Phil
If you're using DSS, you can get a good approximation of ERF in a macro, without having to write an external function. See http://models.metasd.com/2010/05/cumula ... tribution/
