I have just installed PLE 5.10.b on an intel mac running snow leopard (which is up to date).
When I try and print a sketch, the printer simply page feeds with no printout. The printer works as expected with other applications.
On the previous version of PLE I could print but it didn't scale properly.
The printer is an Epson cx6600 which is a pretty standard inkjet.
I have a suspicion that I am missing something obvious. Any suggestions?
L.O.
Printing problem on 5.10.b
I testing everything again on OSX 10.6 using a HP OfficeJet G85 and printing works as expected. If you let me know what OSX version and printer you are using I can try to take a look, though it is unlikely I would be able to match the exact configuration.
If it is possible for you to update your printer driver that might help. Otherwise you will likely be stuck with copying, pasting to Preview and printing from there.
Bob,
As I have over a hundred apps on the mac all of which print as expected, I doubt this is a driver problem. Drivers are kept up to date by Apple anyway.
Are you sure that the printing fix code was included in the release? Could it be anything to do with PLE as opposed to any other release?
In case it helps, the printer is an Epson Cx6600 which is a standard inkjet.
Although I am quite happy to copy and paste as a workaround, I don't think you can leave this problem unresolved if you are serious about having a Mac version of your product.
L.O.
L.O.
