file to be downloaded from the SD forum about bulbs
Here is the model to download
Jean-Jacques Laublé
[Edited on 22-10-2010 by LAUJJL]
Jean-Jacques Laublé
- technologies2.mdl
- (3.67 KiB) Downloaded 1137 times
file to be downloaded from the SD forum about lightbulbs
There is another policy that can be applied. Instead of considering gap goals, one can consider ratio goals.
It is difficult to decide which policy is best.
Some technologies converge quicker, some slower.
It probably depends on the initial conditions and the desired share.
I join the second policy model that tries to converge towards ratio of 1.
- technologies3.mdl
- (3.92 KiB) Downloaded 1047 times
Hi Bob
Thank you for the notification.
I have published in format that can be read by the Vensim reader. They are zipped in the joined file.
I will try to post the zipped file in the SD forum too.
[Edited on 23-10-2010 by LAUJJL]
- technologies.zip
- (16.44 KiB) Downloaded 673 times
Bulb lights
Another model that smoothes the additions to avoid too big fluctuations but that generates unforunately som slight fluctuations of the gap of the stock share
- technologies2_smoothed.vpm
- (34.63 KiB) Downloaded 826 times
Bulb lights
Hi Bob
I have tried to upload files with the .vpm format at the SD forum but it said that it does not accept .vmp extension.
So I could only upload a file with .zip extension.
light bulbs
A new file that leaves the total bulbs stable and smoothes automatically the results by lowering the time step.
- technologies4.vpm
- (226.99 KiB) Downloaded 940 times
Here's an alternative version that implements the matrix method from the thread on the SD forum.
Yet another version that's closer to standard SD practice (including a stock adjustment term).
- technologies5-std.vpm
- (213.83 KiB) Downloaded 866 times
The added discussion for the previous two posts is at http://www.systemdynamics.org/forum/vie ... p=929#p929
Oops - somehow I failed to attach the matrix version. Here it is.
Incidentally, I agree that the SD forum won't take .vpm files.
[Evidently the file size is the issue - I removed an embedded vdf and now it should fit. Apparently the upload limit is between 214k and 373k.]
[Edited on 11-2-2010 by tomfid]
- technologies5-matrix.vpm
- (17.61 KiB) Downloaded 940 times
