I would like to have each bar in a bar graph labeled with it percent contribution to the total series plotted. I have attached a % to each bar on a bar graph (marks tab after I double click on the parameter name). But each bar is simply labeled "100%" even though each bar is a different size. Is there a way to have each bar labeled with the "% of the total" in the plotted series? "PercentValue" labeled each bar differently, but alas, each bar was still 100% of itself. I want % of total.
custom bar graph percent of total label
Moderator: Administrator
The 6 bars in the attached jpg represent a single parameter's six subscripts. If I "mark" them with the "Value", they are correctly labeled with the value of the bar. Percent seems to apply to percent of the bar, which is always 100%, and not to the percent that the single bar represents relative to the total set of bars.
- bar graph showing % issue.jpg (130.83 KiB) Viewed 9701 times
