Hello.
I am working in Vensim DSS v5.9e. I have built a great Venapp, and I am trying to add a capability for the user to export the data from a dataset to an Excel file. The manual says that the MENU>VDF2XLS command is just like the MENU>VDF2TAB one and,
"If you use the command MENU>VDF2TAB with no options a dialog will appear just as for the Vensim menu command Model>Export Dataset command."
I implemented the command as so:
BUTTON,"Export Dataset",11,14,,,,,"MENU>VDF2XLS|||",
Nothing happens when I click the button. It does work, however, when I specify a dataset in the command (e.g. MENU>VDF2XLS|baseline.vdf||").
I want the user to be able to pick any dataset in the directory. Why isn't it working? Thank you for your help!
V/r,
Michael
Is VDF2XLS not working?!?! Please help!
Re: Is VDF2XLS not working?!?! Please help!
What happens if you try
BUTTON,"Export Dataset",11,14,,,,,"MENU>VDF2XLS",
Thank you so much! That worked, and I don't know if I would've ever thought to do that.
