Is it possible to store the data generate by Vensim or other SD tools (like Stella / Powersim) into a database (DB) where the data (in the DB) will be used by other application?
DataBase with Vensim or other SD tools
Re: DataBase with Vensim or other SD tools
It can be done directly from Vensim.
Chapter 14 of the DSS reference supplement details how it is done.
I would have thought at the very least the other apps could export to CSV and then imported into a database.
TQ for the reply. Guess I can't use Vensim PLE (free version) to complete the class project. Maybe I should change my topic
Can you suggest other ways to capture the data generated by Vensim PLE. Perhaps to a text file or other files?
You are very limited with PLE (it is designed for learning, not for anything more advanced).
I think the only thing available to you is to display a table, then copy/paste the contents to a text document and work with that.
