When I try to load an external function dll, I receive the following error message:
"External function version mismatch need version 51050 (got -1)"
I can't understand why this is happening and any help would be very gratefully received.
The external function code is written in c and based closely on the example venext.c code supplied with vensim. It compiles without errors and links with vensim.lib. I am using the GNU GCC compiler within the code::blocks IDE.
I am using vensim DSS for Windows version 5.10e under Windows XP.
the c code contains the following definition for version_info function:
int VEFCC version_info()
return(EXTERNAL_VERSION);
With ETERNAL_VERSION being defined in the header file VENSIM.H as:
#ifdef DBLPREC
#define EXTERNAL_VERSION 51051
#define COMPILED_VERSION 51051
#else
#define EXTERNAL_VERSION 51050 /* for external function */
#define COMPILED_VERSION 51050 /* for compiled models */
#endif
there's nothing here that I can see that would cause a value of -1 to be returned to vensim.
error loading external function dll
Re: error loading external function dll
Are you exporting the following function?
return(EXTERNAL_VERSION) ;
If it is not exported from the DLL, Vensim will be unable to call it (which is why I think you are getting -1).
You don't need to link to vensim.lib either with current versions of Vensim.
Hi thanks for your reply.
After much tinkering I've managed to get it to work. Problem was that cobbled function names were being exported as:
_funcversion_info@0
_set_gv@4
_simulation_setup@4
_simulation_shutdown@4
_user_definition@44
_vensim_external@12
_version_info@0
I've managed to change compiler settings to get clean exports of function names without underscores or @'s. Now seems to work.
Thanks again
_funcversion_info@0
_set_gv@4
_simulation_setup@4
_user_definition@44
_vensim_external@12
_version_info@0
Thanks again
