I am writing and reading files using venapp commands. I wish to place the files within a directory structure. I wish to verify the proper path name syntax to place the file into the directory and I need to find out what other vensim command is writing a duplicate file into a different directory.
This is what I have tried. I get two files, one written to Dir1\file.vdf where I intended and a duplicate, file.vdf, written to the model's directory (which is up one level). The problem may be coming from somewhere else in the Sable scripts where these commands are issued, but I just wanted first to make sure that this is the correct syntax to use for writing a file into or reading a file from a directory. I tried writing to another directory, down one level which worked so I believe that the syntax is correct, but I still get the duplicate file written into the model's directory. I don't understand how I'm writing the duplicate file. I have replaced all instances of "file.vdf" with "Dir1\file.vdf" in the script code so I can't have just missed a copy.
Call RunVenappCommand("SPECIAL>LOADRUN|Dir1\file.vdf")
A second question: is there a list of which commands read or write files other than "Chapter 5 Commands Descriptions" Overview found in the vensim help.
(I 'm running 5.10e windows xp service pack up to date under VMware Fusion 3)
unknown source of file written to model dir using command
Moderator: Administrator
Re: unknown source of file written to model dir using comman
I think when you are running the model, it is saving the run to the model directory.
Have you called "SIMULATE>RUNNAME|" and passed in the correct file name (eg, the following instructs the Vensim engine to save the file "run1.vdf" to the "uncertainty" sub-directory)
Call RunVenappCommand("SIMULATE>RUNNAME|Uncertainty\run1.vdf")
