Delay
nadia
Delay
Post by nadia »
Hi everybody,
How to put delay in our model? Is it we just have to put delay mark in our sketch? For example, in Malaysia, we plant paddy 2 times in a year.We have 2 types of seasons which are main season and off season. The main season is in between 1st August to 28 February. While off season is in between 1 March to 31 July. Therefore, there is a delay here. In which it takes 6 months for the paddy to be produce for each season. So how I can solve this problem?
Thank you in advance.
Nadia.
Re: Delay
Are you using Vensim?
If yes, there is a good introduction to delays at
http://www.vensim.com/documentation/ind ... delays.htm
It includes a link to a model that uses lots of different delay types.
Also take a look at the molecules which also have some delay structures within them.
nadia
Re: Delay
Post by nadia »
Yes.Im using vensim.Thank you so much for the info.
Nadia
zarinah
Re: Delay
Post by zarinah »
hi...
how to put delay in stella? is it same with vensim?
Re: Delay
You will need to ask on a forum dedicated to Stella (unless someone on here can advise).
zarinah
Re: Delay
Post by zarinah »
ok.. tq tony...
