data input
zhouchchun
data input
Post by zhouchchun »
hello, everybody, who can tell me how to import data instead of input data by hand in the vensim PLE, the data i need input to much, input data by hand is slowy, who can supply me a fast method of inputting data, thank you
Re: data input
As far as I'm aware, there is no quick way when using PLE.
Re: data input
You can put your data in a .dat format text file, then import it with Model>from .dat format... and load the resulting dataset for comparison to model behavior. To have data drive your model, or for other more advanced data handling, you need a higher version of Vensim.
http://www.vensim.com/documentation/23460.htm
