Performed simulations from a web application with java and I need to keep
files with extension. vdf that are created to simulate.
The problem I have is that when I close the application these files me
disappear. I have to do to get a particular store
Save files with extension .vdf
Re: Save files with extension .vdf
The Vensim DLL should not delete the files when it ends.
Is the Java code deleting the files?
The multicontext dll will delete files on closure, if the wantcleanup flag is set to a nonzero value when you call VensimContextAdd.
I was wrong, not erased, so good.
Now the problem is to overwrite the files, I mean, do a simulation with a thread 1 and I saved the file here: ctxt0001, but if I do another simulation overwrites the old file and do not want to overwrite it, I have to put do not
Thanks again
Thanks again
