Dear Colleague and Vensim expert,
I try to compile a Vensim program using Microsoft Visual Studio 10.0
My operating system is Vensim7 (64 bites)
After asking for compiled vensim run I obtain the fllowing error message :
LINK : fatal error LNK1104 : impossible d'ouvrir le fichier 'LIBC.lib'
Errors while linking sim.dll - make sure complied simulations were propoerly installed .. .
Thanks for help
I use the following mdl.bat:
______________________________________
REM
REM The following should work with Microsoft C/C++ Version 7 (.net)
REM
REM if "%OS%" == "" set PATH="set PATH=c:\Program Files\Microsoft Visual Studio .NET\common7\ide";"c:\Program Files\Microsoft Visual Studio .NET\VC7\bin"
REM if "%OS%" == "Windows_NT" set PATH=c:\Program Files\Microsoft Visual Studio .NET\common7\ide;c:\Program Files\Microsoft Visual Studio .NET\VC7\bin
REM set LIB=c:\Program Files\Microsoft Visual Studio .NET\vc7\lib;c:\Program Files\Microsoft Visual Studio .NET\vc7\PlatformSDK\lib
REM set INCLUDE=c:\Program Files\Microsoft Visual Studio .NET\vc7\include;c:\Program Files\Microsoft Visual Studio .NET\vc7\PlatformSDK\Include
REM
REM The following should work with Microsoft C/C++ Version 6
REM
REM if "%OS%" == "" set PATH="c:\Program Fles\Microsoft Visual Studio\common\MSDev98\bin";"c:\Program Files\Microsoft Visual Studio\VC98\bin"
REM if "%OS%" == "Windows_NT" set PATH=c:\Program Files\Microsoft Visual Studio\common\MSDev98\bin;c:\Program Files\Microsoft Visual Studio\VC98\bin
REM set LIB=c:\Program Files\Microsoft Visual Studio\vc98\lib
REM set INCLUDE=c:\Program Files\Microsoft Visual Studio\vc98\include
REM
REM The following should work with Microsoft C/C++ Version 5
REM
REM if "%OS%" == "" set path="c:\Program Files\DevStudio\VC\bin";"c:\Program Files\DevStudio\SharedIDE\bin";
REM if "%OS%" == "Windows_NT" set path=c:\Program Files\DevStudio\VC\bin;c:\Program Files\DevStudio\SharedIDE\bin;
REM set LIB=c:\Program Files\DevStudio\VC\lib
REM set INCLUDE=c:\Program Files\DevStudio\VC\include
REM
REM The following should work with Microsoft C/C++ Version 4
REM
REM path=c:\msdev\bin
REM set LIB=c:\msdev\lib
REM set INCLUDE=c:\msdev\include
REM
REM The following lines actually do the work
REM
call "C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\vcvars32.bat"
if exist mdl.obj del mdl.obj
if exist sim.dll del sim.dll
if exist simdll32.dll del simdll32.dll
if exist simdlx32.dll del simdlx32.dll
CL /O2 /c /DWIN32 mdl.c
if errorlevel 1 goto :error1
if not exist mdl.obj goto :error2
LINK /DLL /OUT:sim.dll /def:%1sim.def mdl.obj %1simext.obj %1vensim.lib
if errorlevel 1 goto :error3
if not exist sim.dll goto :error3
REM
REM The following line will create a simdll32.dll file for use with
REM the full Vensim DLL
REM LINK /DLL /OUT:simdll32.dll /def:%1sim.def mdl.obj %1simext.obj %1..\dll\vendll32.lib
REM if errorlevel 1 goto :error4
REM if not exist simdll32.dll goto :error4
REM
REM The following line will create a simdlx32.dll file for use with
REM the redistributable Vensim DLL
REM LINK /DLL /OUT:simdlx32.dll /def:%1sim.def mdl.obj %1simext.obj %1..\dll\vendlx32.lib
REM if errorlevel 1 goto :error5
REM if not exist simdlx32.dll goto :error4
REM
del sim.lib
del sim.exp
goto :exit
:error1
echo There were errors while compiling - check the paths in mdl.bat in vensim\comp
goto exit2
:error2
echo Unable to compile. You probably need to set paths in mdl.bat in vensim\comp
goto exit2
:error3
echo Errors while linking sim.dll - make sure compiled simulations were properly installed
goto :exit2
:error4
echo Errors linking for use with the full dll - check that ..\dll is the right directory
goto :exit2
:error5
echo Errors linkinf for use with the redistribution DLL - check that ..\dll is the right directory
goto :exit2
:exit2
pause
goto :exit3
:exit
echo ----------
echo Compilation of sim.dll seems to have been successful.
echo Close this window and continue.
:exit3
Problems with vensim compilation
Re: Problems with vensim compilation
What version of Vensim are you using?
You could also try changing
to
LINK /DLL /OUT:sim.dll /NODEFAULTLIB:libc.lib /def:%1sim.def mdl.obj %1simext.obj %1vensim.lib
I'm not sure it will work though. I've seen the error you specify before when using a MDL.BAT from an old version of Vensim.
to
I'm using Vensim 5.4a released August 2004.
The porblem has benn fixed yesterday evening on my laptot with OS windows7 32 bites.
But I still have prmble with my destop wit OS Win7 64 bites.
Best Regards
Best Regards
Have you tried the modified link line I suggested?
I just used that modification
It's OK now on my desktop !!
Thanks Very Much
Thanks Very Much
