Hi everybody
I am presently trying to override the behavior of a variable using the synthesim mode with a model published with the Vensim player using the Vensim player.
It does not seem to work. Is it possible to do it or not? The model published is in .vpm format, but if open with Vensim says 'model blocked for this application'.
Of course one can open with the Player, but overriding does not work.
Thanks in advance.
Best regards.
overriding behavior in player mode
Re: overriding behavior in player mode
Hello JJ,
At the moment overriding does not work in the Model Reader. I'll check the status and get back to you.
