Mac compiled simulation issue (DSS)
It appears that an issue with the installer may prevent installation of a needed file for compiled simulation on the Mac in 5.10d.
To fix, decompress the attached archive (
simext.zip
(5.5 KiB) Downloaded 700 times
), drop the enclosed file (simext.c) into your compiled simulation directory (normally Users/Shared/Vensim/comp) - everything should work after that.
This is only relevant if you're running compiled simulations in DSS (per http://blog.metasd.com/2011/03/vensim-c ... n-the-mac/
T
