Lookup Table
maxin454
Lookup Table
Post by maxin454 »
Hi. When I invoke a lookup table for the first time after starting a java vensim application, the table appears behind all other windows currently opened. However, after the first time, the table will be opened in the front, which is what I want. Is there a way to set the lookup pop-up windows always on top in the java application? I'm using "SIMULATE>1TABCHG|varname" to invoke the lookup table. Many thanks.
maxin
Re: Lookup Table
Have you called the vensim_set_parent_window function? Call this and pass in the window handle to your main app window and it should work fine.
http://vensim.com/documentation/index.html?26240.htm
maxin454
Re: Lookup Table
Post by maxin454 »
Hi. Yes, it does not seem to work. The vensim manual mentioned this command does not work in java environment? However I observed an interesting behavior and let me describe it to you. On Windows 7 machine, when open my application (.vpa) for the first time, a .jar (caller) will be extrated. The main screen of my application has several "buttons" for invoking the lookup table. When first lookup table is invoked, the table is behind the main screen. Interestingly, after that, the invoked table will appear correctly, which is in front of the main screen. If you close the application, and reopen the application, even the first lookup table invoked will go to the back. Also, I tested on Windows XP, the lookup tables all appear in front of the main screen with no problem. Any suggestions? Many thanks.
maxin
maxin454
Re: Lookup Table
Post by maxin454 »
Another observation, if the vensim DSS is installed, the lookup tables all appear in front of the main screen, in both Windows 7 and XP environment.
maxin
Re: Lookup Table
Can you email the vpa to me for testing?
vensim@vensim.com
maxin454
Re: Lookup Table
Post by maxin454 »
Dear Administrator,
Thanks again. I've sent an email to you.
maxin
