Is there any way to get a slider to operate between 0 and 1? I tend to use these values for percentages e.g. 0.45 rather than 45%.
David
Slider Range
Moderator: Administrator
Re: Slider Range
Set the min to 0, max to 1, and the tick frequency to .1 (or whatever you need it at).
Is this not working for you?
Re: Slider Range
Thanks - yep it does work. Just didn't think about the 'tick' range. I learn something every time I create a new interface. However it leads to another issue. I'm using subscripts - in this case 'male' and 'female'. Using the edit box I can get it to 'display all combinations' and thereby display the male or female subscript elements. The slider doesn't allow this. I can edit it directly and change the range 'gender' to either of the subscript elements and it seems to work. However, when I do that the reset button I've set up does not work.
Thanks again or your prompt and helpful replies.
David
David
Re: Slider Range
Can you email me the screen with the problem and I'll take a look?
