Is there anyway to show, as you can in vensim, the name of the simulation run you are seting up. At this stage when you load runs the name of that run is not visible. Is there a way of doing this?
David
Show the Simulation Run
Moderator: Administrator
Re: Show the Simulation Run
Add some text to the screen, and in it enter
The @RUNNAME@ will be replaced with the current run name.
You can also use
and the following to display the runs that are currently loaded.
Runname = @RUNNAME@
You can also use
@RUNNAMENOPATH@
@RUN0@
@RUN1@
@RUNn@
David
David
