Bug of Model Reader
yusuke
Bug of Model Reader
Post by yusuke »
I thank this forum of kind support.
My report of model reader.
In 5.11A of Mac,
* Dont move Model > Simulate , Simulation Button and Ctrl+R is OK
* In Model Setting mode, Changes >Write Changes Made to .cin and Read Additinal Chagnges from file is gray out.
after simulation,
* Write Changes Made to .cin is located in layout menu
i think it should be active before simulation
In Windows,
Re: Bug of Model Reader
If your model is small, hitting Model>Simulate may perform a run so fast that you can't see it.
Reading and writing .cin files is not intended to be enabled in the Model Reader.
yusuke
Post by yusuke »
Oh, I understand Model reader can't manage cin file.
About model>simulate,
If there is a dataset using same name, "overwrite" dialog will show.
But there is no information.
So, I think this command is not accept.
But for me "simulation button" is enough
When you say there is no information in the overwrite dialog, do you mean that the dialog text is missing? That would be a bug.
