Hi All,
I am using vensim version 5.10e dll in visual basic. How do i use the Vensim SETTING> command to get the Initial Time and the Final Time and also how to set a new value for both the Initial Time and the Final Time.
Thanks.
How to use the SETTING> comand to get the Initial Time
Re: How to use the SETTING> comand to get the Initial Time
Use vensim_get_val to get initial and final time values.
To set them, use vensim_command, the command should be "SIMULATE>SETVAL|INITIAL TIME = 999"
thanks a lot. it worked
