missing arrows
thrillz84
missing arrows
Post by thrillz84 »
I am building a model and i notice after a while some arrows become invisible and when I try creating new arrows between the variables it gives me a message "this connection exists.do you want to remove the old arrow?"Please hw can I stop these arrows from being invisible?
Re: missing arrows
Can you post the model that is causing the problems?
Wilson
Re: missing arrows
Post by Wilson »
Are the missing arrows from Initial Variables, such as the starting value of a Level? If so, the default option in Vensim is to hide these. To change the default, go to Model>Settings>Sketch and check the first option.
thrillz84
Re: missing arrows
Post by thrillz84 »
done exactly thay and the arrows are back in grey,thanks....is there any reason these are hidden or are they ideally meant to be hidden?
Re: missing arrows
They are hidden by default because they don't affect the dynamic structure of the model. I actually prefer things the other way, so I generally use the Model>Settings to turn them on, then manually hide any arrows that cause visual clutter. Then you can show/hide them as needed by hitting the H key (or menu).
thrillz84
Re: missing arrows
Post by thrillz84 »
many thanks
