missing arrows
Posted: Thu Apr 11, 2013 5:05 pm
by thrillz84
I am building a model and i notice after a while some arrows become invisible and when I try creating new arrows between the variables it gives me a message "this connection exists.do you want to remove the old arrow?"Please hw can I stop these arrows from being invisible?
Re: missing arrows
Posted: Thu Apr 11, 2013 5:44 pm
Can you post the model that is causing the problems?
Re: missing arrows
Posted: Thu Apr 11, 2013 6:00 pm
by Wilson
Are the missing arrows from Initial Variables, such as the starting value of a Level? If so, the default option in Vensim is to hide these. To change the default, go to Model>Settings>Sketch and check the first option.
Re: missing arrows
Posted: Thu Apr 11, 2013 7:23 pm
by thrillz84
done exactly thay and the arrows are back in grey,thanks....is there any reason these are hidden or are they ideally meant to be hidden?
Re: missing arrows
Posted: Thu Apr 11, 2013 10:10 pm
They are hidden by default because they don't affect the dynamic structure of the model. I actually prefer things the other way, so I generally use the Model>Settings to turn them on, then manually hide any arrows that cause visual clutter. Then you can show/hide them as needed by hitting the H key (or menu).
Re: missing arrows
Posted: Fri Apr 12, 2013 9:19 am
by thrillz84
many thanks
