Custom tables: operation with variables
apix
Post by apix »
I'd like to show the variation of value for a selected variable for the first two loaded runs.
Maybe I can use a custom table.
is it possible, in a custom table, to show the difference of values of two loaded runs for the selected variable?
Something like
:VAR varname &*1 - varname & *2
Many thanks
Re: Custom tables: operation with variables
Have you tried custom reports? They might do what you need (I haven't actually used them in years so am very rust on it).
http://www.vensim.com/documentation/ind ... ?24035.htm
I don't think it's possible to perform mathematical operations on the two runs.
An alternative, if these represent something like a "base" and "policy" scenario, is to subscript the entire model with a scenario dimension, e.g. scenario : base, policy, so that both runs happen at once. Then you can calculate differences, etc. directly.
apix
Post by apix »
Not about operations but custom tables....
If I use just
:table table1
:comline Population
:var population
without specifying any dataset but loading more runs, only the values of the first run are shown.
I can't know if more runs will be loaded, thus I don't want to use che :DATASET dataset key.
What can I do?
I don'd understand your question. Can you try and explain again?
Generally, if you use the : DATASET key with a wildcard like *2 (for the second run), nothing will be shown if only one run is loaded, so you don't need to know in advance what is available.
