I’ve entered a tabbed array in vensim. (No problem here. I imitated the sample and VENSIM seems happy enough.)
How do I have the model read a value out of it and assign it to a variable? Based on other instantaneous states in the model, I want x to be the value in row 3 column 5 of the array for this time step in order to make further calculations. Later, row 2 column 1. I have a variable for desired row, and a variable for desired column (eg. r=2 and c=1 for row 2 column 1)
Background/project:
I’m using vensim to model rivers and reservoir systems, and I’m using lookups for things like “reservoir release for ecosystem health” that changes based on a weather classification (wet, dry, or normal) and the time of year (monthly). It would be a 3 row, 12 column matrix.
It is currently programmed in as 3 lookups with 12 values each (f_wet, f_dry, and f_normal),
a function defining the weather patterns,
weather classification =
IF THEN ELSE (cumulative rainfall<3, 1, // dry
IF THEN ELSE (cumulative rainfall<7, 2, // normal
3)) // wet
and then another if statement choosing the correct lookup and pulling the value based on month.
release for ecosystem health =
IF THEN ELSE (weather classification = 1, f_dry(month), IF THEN ELSE (weather classification =2, f_normal(month), f_wet(month)))
This setup works and has been running, but I’m now looking at weather in a higher resolution (more categories for rainfall), and at different sets of releases for different reservoirs, and the number of variables is getting out of hand. (f_verywet_reservoir1, f_verywet_reservoir2, etc.)
I’m envisoning one definition of weather classification and one function to count the month, plus one tabbed array for each reservoir to assign a value to that reservoir’s release.
Potentially something like
variable =
LOOKUP FUNCTION OF SOME KIND (name of tabbed array, row, column)
which in my case would become
reservoir 1 release for ecosystem health =
LOOKUP FUNCTION OF SOME KIND (reservoir 1 array, weather classification, month)
Am I completely misunderstanding the purpose of tabbed arrays? If not, how do I read the release out of the tabbed array?
Thanks in advance for your help!
reading a value from a tabbed array
Re: reading a value from a tabbed array
Unfortunately there is no in-built function, but I have added a model that allows you to do this.
You use SUM to loop over the elements in the array, and select the correct one.
- TABBED ARRAY select element.mdl
- (2.84 KiB) Downloaded 216 times
There are probably other ways to arrange things, using VECTOR ELM MAP for example.
I'm using the sum/loop solution.
