Attaching Table between two Variables in the SD Model
DN Gupta
Post by DN Gupta »
Subject: Queries for VENSIM PLE Software for system dynamics application: Attaching Table between two Variables in the Model
7.8.2013
Hello!
I am using VENSIM PLE Software for system dynamics application for research work.
I have one question.
How to give Table function between two variables (It is required, in case the variables are linked through tabular data, and as such there is no equation between the two variables).
It is suggested that the Table can be created in Excel and then attached into the Model. It is tried so.
But, how to connect Excel Table in VENSIM Software, while developing Model. In the Window / Dialog Box for giving equations, which is the functional button to attach Excel Table.
Can it please be explained with one simple example?
DN GUPTA
Re: Attaching Table between two Variables in the SD Model
Is this what you're after? http://vensim.com/lookups-in-vensim/
Also, check Chapter 8 of the User Guide. http://www.vensim.com/documentation/usr08.htm
