function to retain another variable at time T-1
thrillz84
Post by thrillz84 »
Hi there,
Please is there any technique or function I can use to hold the value of a variable such that variable "A" at time T or T+1 will have the value of a variable "B" at that "T" or "T-1" respectively. Many thanks
Olu
Re: function to retain another variable at time T-1
Take a look at SAMPLE IF TRUE or DELAY FIXED. One of these should do what you need.
thrillz84
Post by thrillz84 »
perhaps mixed it up..I need a function that can perform the opposite of the delay function i.e a function that will let a variable "A" at time T to hve a value of a variable "B" t time T+1
Vensim (and reality) is causal - that is, no variable can use information about the future.
Can you say more about the reason for this approach?
thrillz84
Post by thrillz84 »
cheers Tom, in the attache model for example, I need a function that will let variable "y" have values of 0.94, 0.909651...at times t= 1 and 2 ....theoretically i know it isnt right but I need it or some analysis...tnx
example.mdl
(15.1 KiB) Downloaded 475 times
There is no function that can do that. You can try using FORECAST or TREND. Otherwise, you would need to calculate the model a time step in the future.
There is a trick you could do though - cumbersome in general, but feasible in a simple model. Create an auxiliary that calculates the value of the stocks ahead a unit of time (assuming Euler integration):
future bad code = bad code + roc*TIME STEP
Then use can use the "future" stocks to calculate other future variables.
thrillz84
Post by thrillz84 »
cheers Tom!!!should have thought of that
The other possibility is to just put minus signs in all your integrations, and run the whole model backwards. :mrgreen:
thrillz84
Post by thrillz84 »
:D splendid!!
