about model time step setting and function use
Posted: Tue Oct 29, 2013 5:01 pm
Hi Tony,
I have two questions about model time step and a function "GET XLS DATA".
1. I set annual as my model time step (figure 1 left), and run the game for one time step (2014-2015), why the model shows some sub-annual time (such as 2014.20, 2014.40) in the time axis (figure 1 right)? How can I set the model to show 2014 and 2015 only.
2. I am trying to use the function "GET XLS DATA" to read some time series data from an excel file into the model. When I run the model in the "GAME" format, the model results (figure 2 up) does not match the values in the excel file (figure 2 down). I also attached a simple example to show this. Run the model "test.mdl" in the GAME format, and compare the results with excel file, you will find the problem showing in figure 2.
Vensim version: DSS 6.1C
Computer system: Windows 7
Many thanks!
Kai
Many thanks!
Kai
