Problems with Sample Yeast Culturing Model?
Posted: Mon Mar 03, 2014 6:30 pm
I am using a sample Vensim model of yeast growth and decline in my graduate course on systems modelling. The model used to work quite well, but without any changes to the model except for an update to Vensim PLE version 6.1, the behaviour now seems very sensitive to small changes in the temperature. For example, with a normal culturing temperature of 29 degrees, and a "dormancy temperature" of 10 degrees, I would expect to find yeast growing almost normally at 22 degrees. Instead, the yeast count grows only very slowly, reaching a maximum of 1600 cells at 300 min. Under normal conditions, the cell count grows and then collapses, with a maximum cell count of ~60000.
Can you tell me why the model is so sensitive now? (I can change the lookup tables to fix the problem, but I am wondering specifically whether anything changed in Vensim from version 5.9 to 6.1 that might have affected the model behaviour.)
