I would like to check if there has been changes made to the Sketch comment functionality in the Vensim 6.2? I used to draw a box and added background color to separate different sub-models in one view. However, I noticed last week that I am unable to have this function - that is, the sketches are not send forward.
Can someone let me know what happened to this functionality.
Vishah
Sketch comment
Re: Sketch comment
I assume you are using Vensim, is that correct?
And can you post a model demonstrating what you mean?
Re: Sketch comment
Yes, I am using vensim. Attached find a simple model demonstrating my question.
- Test model 1.mdl
- (2.78 KiB) Downloaded 451 times
Re: Sketch comment
Rafael
Rafael
- Sketch.png (254.94 KiB) Viewed 5815 times
- Test model 1.mdl
- (2.74 KiB) Downloaded 475 times
Re: Sketch comment
On the bottom toolbar in Vensim, there is a button to "Push the highlighted words to the background". Select the comment, then click the button and it should give you what you want.
