Can Lookups deal with variables in the output
karankhosla
Post by karankhosla »
Is it possible to define a lookup table so that it chooses the output as a variable in the model rather than a number; so for example:
The lookup data set would be some thing like [(1, VarA), (2,VarB), (3, VarC)]
Re: Can Lookups deal with variables in the output
There is no way I know of to do this.
How many variables do you need to choose from? And are they individual variables or part of a subscripted parameter?
And do you need to interpolate between the points at all?
This can be done with VECTOR LOOKUP - http://www.vensim.com/documentation/fn_ ... lookup.htm
