Hi Tony,
I am using Vensim DSS and trying to run a model with stochastic elements to it. I need to have repeated runs where random distributions change in each run.
How do I do this? I can only find how to change parameters in sensitivity
simulations.
Lynda
Multiple runs of a stochastic model
The easiest way is to change the noise seed for the random number generation and do lots of batch runs (see
http://www.vensim.com/documentation/html/25670.htm for details on how to automate this process using a command file). Basically change the noise seed and save each run under a different name.
Is this what you are after?
