Delay 1 behaviour
Posted: Tue Oct 28, 2014 6:05 pm
Hi all
I run Vensim Professional on Windows OS 7.
The behaviour of Delay 1 should be the same as a first-order delay. However, when I use a constant inflow, the outflow equals the inflow, ignoring the Delay 1 function. It does not matter what Time Step I use.
I tested it on the attached model, on the DELAY 1 3 N P.mdl sample model in the tutorial, as well as the DelaySandbox1 model in Tom Fiddaman's Model Library (Am I glad I discovered the library - thank you very much Tom).
Why does the behaviour of the Delay1 function differ from a first-order delay if the input is a constant value?
Schalk
Schalk
