Get subranges?
Get subranges?
I can use GET SUBSCRIPTS to read in subscripts but how can I add or map subranges to it if the names of subscripts are not known in advance?
Re: Get subranges?
Can you upload a simple model demonstrating what mapping you need to do? There may be a way to do it.
Re: Get subranges?
I'd like to map the subranges in column B to the range in A. Trouble is that the number of elements in the subrange categories can change and should adjust itself to the data sets. Any thoughts?
- Subrange.xlsx
- (8.75 KiB) Downloaded 324 times
- subrange.mdl
- (1.16 KiB) Downloaded 310 times
Re: Get subranges?
Can you work with these files?
Read in the subscripts as before, but create a cross reference matrix. Then use this as a multiplier to convert
- subrange.mdl
- (2.06 KiB) Downloaded 309 times
- Subrange.xlsx
- (10.95 KiB) Downloaded 321 times
Re: Get subranges?
Thank you for your suggestion. As I would be dealing with 700 x 70 items a matrix does get a bit more complex in Excel. I have attached a solution which uses indexed subscripts - as one cannot calculate (especially references) with subscripts in vensim I use variables for doing so. Any thoughts which approach is better?
Is there a way around the necessity to call GET SUBSCRIPT with two fixed cell references? Using a different data set with a different structure requires also changing the model which a user won't like doing.
- Subrange.xlsx
- (11.08 KiB) Downloaded 303 times
- subrange v3.mdl
- (2.48 KiB) Downloaded 325 times
Re: Get subranges?
I'll raise this a feature request.Is there a way around the necessity to call GET SUBSCRIPT with two fixed cell references? Using a different data set with a different structure requires also changing the model which a user won't like doing.
Regarding which method is better, it's really a matter of personal preference (and ease of understanding).
