import custom image to replace cloud icons
bppro
Post by bppro »
Dear Vensim gurus,
I am using VensimDSS on a macbook pro retina (Yosemite 10.10.1). I am trying to replace the cloud icons with my own generated bmp image.
To do so, I right-click a cloud and then use the "import" option. Then, I choose my file and click "ok". At that moment, Vensim returns me the error "Don't know how to import /path/to/my/file".
Do you know how I could fix this problem?
Thank you very much,
BP
Re: import custom image to replace cloud icons
It works fine for me. Is the image a valid bitmap?
bppro
Post by bppro »
How can I verify if my image is valid? It has the .bmp extension.
Could you share your image with me so that I can try it on my machine? At least we'll know if that's the problem.
Here is the image I used.
bppro
Post by bppro »
I can use your image. That means I must be doing something wrong when creating my .bmp file.
Thank you. I will try a different tool to create my bmp file and see if that helps.
What are you using to create the bitmap? Is it an Apple application?
bppro
Post by bppro »
Yes, I am using Apple applications. I have tried paintbrush (http://paintbrush.sourceforge.net) and Autodesk Sketchbook from the app store.
Are Apple applications not capable of producing valid bmp files for Vensim?
bppro wrote:Are Apple applications not capable of producing valid bmp files for Vensim?
They should be. Bitmap is a standard, if those apps are not producing standard bitmaps, there is nothing we can do.
