DDE with Win 8.1 VM
drw
DDE with Win 8.1 VM
Post by drw »
Trying to use DDE to connect Excel to Vensim DSS on a windows 8.1 virtual machine (VM) which seems to hang Excel (specifically when you call DDEInitiate). I have no problems with the same VBA script (code reproduced below if needed) on a standard PC with windows 8.1 and vensim DSS. Also a previous incarnation with windows 7 VM and Vensim worked with no problem. Does anybody have ideas what is different on a win 8.1 VM or some process that I need to ensure is running on the VM for DDE to work?
Many thanks in advance,
Dave
Option Explicit
Dim DDE_channel As Integer
Function StartupDDE() As Boolean
    Dim blnIsRunning As Boolean
    On Error GoTo Err_Handler
    blnIsRunning = VensimRunningCheck
    'Check to see if Channel Number has already been assigned
    If Not DDE_channel > 0 Or blnIsRunning = False Then
        'Channel not assigned - check to see if Vensim running
        If blnIsRunning = False Then
            'Vensim not running - try to open
            Dim RetVal
            RetVal = Shell("C:\Program Files (x86)\Vensim\Vensim.exe", vbMaximizedFocus)
            AppActivate "Microsoft Excel"
            Excel.Application.Visible = True
        End If
        'Connect to Vensim
        DDE_channel = Application.DDEInitiate("VENSIM", "System")
    End If
    StartupDDE = True
    Exit Function
Err_Handler:
    MsgBox "There was an error trying to connect to Vensim.  Please close and reopen Vensim manually", vbExclamation + vbOKOnly, "Vensim Connect Error"
    StartupDDE = False
End Function
Re: DDE with Win 8.1 VM
What versions of Office do you have running on these various machines?
drw
Post by drw »
Using Office 2010. But also tried Excel 2007 and Excel 2003. Same result for all three.
Dave
You could try copying the vensim.ini file from a working machine to the VM and see if that works. You will find it in %APPDATA%\vensim.
Beyond that I'm not sure what to suggest. I don't have the resources to set up a 8.1 VM with Office (and I'm sure it's just a config issue anyway).
