Bar graph
Moderator: Administrator
CK_DTAG
Bar graph
Post by CK_DTAG »
I use Sable Dev version 5.1.485 on Win 7 computer (64 Bit)
and got the following problem:
I’d like to insert a bar graph showing all values (in my case a period of 60 months):
Properties:
I select a parameter (Auxiliary variable) and in the Dialog window
General
- Series type: Bar
- Series mode: Display all vals
All other properties are by default.
The graph doesn’t show any value.
If I take Series mode ‘Display at time’, I get one bar (at final time).
But how do I get all values?
I also tried to change all other properties, without success.
In Vensim (DSS v6.2) the bar graph works fine. In Bar Graph Options I select ‘As time-graph’ and all values are shown.
Many Thanks in advance for any solution.
Christian
Re: Bar graph
Can you upload the screen file (or email it to me)? I'm sure it's just a setting that needs setting.
