how to sign a range for a stock variable
memphis15
Post by memphis15 »
on the equation input, i signed the min and max values, but it did not work. Any suggestion?
Re: how to sign a range for a stock variable
The min/max will not stop a stock going lower/higher than those values.
If you want to have a min/max, you will need to do it with model structure. Limit the amount entering/exiting the stock so that it stays within the bounds you have set.
memphis15
Post by memphis15 »
thanks a lot!
