Problem adding columns to builtin dataset editor
Posted: Thu Oct 22, 2015 12:41 pm
by Phill
I followed the exercises in the Ventity manual and got as far as exercise 3 without any problems. I tried to move straight from exercise 2 to exercise 3 so, having finished exercise 2 and leaving the program open, I added the 'Cows' entity, then the associated auxiliary variable and attribute. Following the instructions I then opened the 'Builtin dataset editor for Input 1: many pastures' to enter the list of cows and assign their consumption rates on the 'Cow' entity tab. But when I opened that panel there were no columns for 'pasture' or 'consumption', as shown in the illustration in the manual, and I could not find any way of adding them. Then I closed the model and reopened it and found that the 'consumption' column had appeared. There is still no column for the 'pasture' attribute, as you can see from the attached screen shot.
Re: Problem adding columns to builtin dataset editor
Posted: Thu Oct 22, 2015 2:32 pm
by Phill
Here's the model I am referring to. I would be very interested to know if anyone else can see the Pastures column on the Cows tab in the 'BuiltIn: many pastures' input data table (or point out where I've gone wrong). In the model as I am viewing it, there doesn't seem to be a way to link the cows to the different pastures,
Posted: Thu Oct 22, 2015 2:50 pm
My guess is that you added the Pasture attribute after creating the builtin dataset that populates the cows, right? Unfortunately, there's a bug that prevents the dataset from updating to reflect the new attribute. If you create a new builtin dataset, the Pasture column should be included. This'll be fixed in the next beta release. (Actually, there are quite a few improvements in this area.)
Posted: Thu Oct 22, 2015 3:16 pm
by Phill
Thanks Tom. I had tried making a duplicate of the dataset, but that didn't make any difference. Adding a new one, though, did include the pastures attribute, which I had added after creating the original dataset, as you say.
Posted: Fri Oct 30, 2015 8:27 pm
This is fixed in the latest release. Unfortunately there are a couple of other glitches in the input data infrastructure, but they don't cause rework like this does.
