I have a question regarding use of an external data source. You will find attached a model where I used both the internal and the external data source, which give identical simulation results. My question goes towards the input of a table function. I used the format indicated in the table (X1,Y1),...,(Xn,Yn), which seemed to work properly.
However, how could I do this in a more automatised version, instead of doing it manually?
