Getting a string from a VDF
Posted: Fri Sep 09, 2016 4:07 pm
by SionC
Is it possible to get a string variable value from a VDF file via the DLL?
Re: Getting a string from a VDF
Posted: Sat Sep 10, 2016 8:00 am
No. I'm not sure they are even stored in the VDF (I'm re-working the format at the moment and haven't come across any string storage at all).
Posted: Mon Sep 12, 2016 7:59 am
by SionC
They are there, see the attached VPM file with three VDF files loaded. Refer to the variable SAMPLE STRING VARIABLE.
I am using string variables to store additional run information. It would be great to be able to get the information back into Excel via the DLL. It would also be an issue if it is no longer possible to use this functionality.
Best wishes
Sion
Posted: Mon Sep 12, 2016 2:58 pm
Could you encode the string information as numbers, or are they ad hoc and numerous?
Posted: Mon Sep 12, 2016 3:17 pm
by SionC
Hi Tom,
Sadly it is ad hoc information, for example a text description of a particular scenario.
Best wishes
Sion
Posted: Mon Sep 12, 2016 3:50 pm
I should be able to add a new function to the DLL to retrieve the string variables. Just need to find the correct place in the code.
Posted: Mon Sep 12, 2016 4:44 pm
It should be available in the next release of Vensim.
Posted: Tue Sep 13, 2016 7:58 am
by SionC
That is fantastic! Thanks :)
Posted: Tue Nov 15, 2016 8:56 am
by SionC
Is this functionality planned to be in the December release of Vensim 6.4E?
Sion
Posted: Tue Nov 15, 2016 9:06 am
Yes.
