i'm trying to use dlls of Vensim 3 under WinXP. I first tried it with visualWork7nc with no succes since Vensim commands just don't work. I then tried the vendll.xls example supplied with the vensim3.0 software. Alltough I correctly renamed vendll32.dll file, I put the vensim.ini at the right place and I modified the paths in vendll.xls, it also didn't work and when calling vensim commands I still get 0 as result. Could you give me any advice? I was told that I should maybe modify the MDL.BAT file but in which way? Idon't know!
Thanks in advance, Manuel
dll and vensim
Moderator: Administrator
dll and Vensim
Hello Tony,
here are the files I use. Good luck,
Manuel
ps : I corrected the paths of the Manu.xls file that effectively were wrong (shame on me!)
Manuel
