Was wondering whether in Vensim there is an option than when you export a data matrix that it can automatically truncate the data matrix to get rid of zeros?
For example if you have a matrix from 1970 to 2050 (you want each year to appear), but on the X axis you might have more than 100 countries, but some of these countries for some of the variables across the time series 1970 to 2050 are always 0. So in other words could Vensim already identify automatically those that for the cumulative time period 1970 to 2050 and delete them/or not export them?
This could make in certain cases of exporting data the exported data file smaller.
Thanks, Pawel
Exporting data without zeros
Re: Exporting data without zeros
Not really. We'd need to program into Vensim the ability to check a time series for zeros and not output them. Also we'd need some way of implementing this in the user interface. This is not really what Vensim is designed for, data manipulation like this needs to be done via a programming language, so Excel and some simple VBA would be the correct way to post-process the file.
Thank you for the prompt reply.
Agree that this could be done in Excel with VB for example.
But still could be a useful tool to have in Vensim directly as would make the analysts concentrate more on the output of Vensim rather than manipulating it.
Pawel
Pawel
I'd argue that ignoring the zeros is manipulation of the output. Depends on the model/usage of it though.But still could be a useful tool to have in Vensim directly as would make the analysts concentrate more on the output of Vensim rather than manipulating it.
I cannot think of any generic way of programming something like this into the user interface. It is custom manipulation, the only way to do it is via a programming language (or manually in Excel). But Excel can record your actions, so it could easily be done once, and the resulting code modified to make it more generic.
Thank you again
I can't remember how the export treats NA values, but it's possible that you could create an extra variable:
x no 0s = IF THEN ELSE( x = 0, NA, x )
and export that. The NAs might get skipped or left blank.
