VDF2TAB and Time (in Command File)
Posted: Tue Jul 25, 2017 1:37 pm
by apix
I'm experiencing a strange behaviour in the tab file created with the command VDF2TAB in a Command Script.
No particular option is given to the command, which has the form: MENU>VDF2TAB|vdffile|tabfile|savelist|
The strange behaviour is about the Time header.
The model runs from 1995 to 2030, but some variables are ouput in the tab file in the interval 1965.75 - 2074
Of course no value is provided for the years outside the interval 1995 - 2030, but, from aesthetic point of view, the result is not so "attractive".
Furthermore, even if the SAVEPER option is set to 5, the Time headers include every year and some (just some!) quarters of year.
I managed to avoid the visualization problem by adding the frequency, start and end option for VDF2TAB, but I'm curius to know the origin of these other years.
Thank you in advance.
Re: VDF2TAB and Time (in Command File)
Posted: Tue Jul 25, 2017 1:57 pm
Can you upload the VDF and the exact command you are using?
Posted: Tue Jul 25, 2017 2:15 pm
Are there data variables in the model? Data often has its own time axis.
Posted: Wed Jul 26, 2017 9:09 am
by apix
The exported variables include data variables, but these, as all inputs and ouputs refer to the interval 1995-2050.
The funny thing is that nowehere it is set the wider interval 1965-2074. I wonder if they are default dates.
Posted: Wed Jul 26, 2017 1:09 pm
Strange. I think we'd need the .vdf and exact command to diagnose. You can post it, or email if sensitive.
Posted: Wed Aug 02, 2017 4:08 pm
by apix
HI,
I've prepared the vdf file, where can I send it to by email?
Posted: Wed Aug 02, 2017 4:10 pm
How large is the VDF?
Posted: Thu Aug 03, 2017 7:42 am
by apix
423 MB
Posted: Thu Aug 03, 2017 7:44 am
Email is not an option then, it's far too large.
Can you upload it somewhere so we can download it?
Posted: Thu Aug 03, 2017 8:18 am
by apix
https://drive.google.com/file/d/0B6hO-H ... sp=sharing
the zip folder contains 4 files:
- Scenario_1.vdf
- VDF2TAB.cmd , the command used to generate:
- Scenario_1.tab , which present the unexpected Time headers
- VDF2TAB_with_start_end.cmd , the command used eventually to avoid the strange Time headers
Posted: Thu Aug 03, 2017 8:57 am
Do you have the save list as well? The tab file it creates is 1.4gb in size.
Posted: Mon Aug 07, 2017 3:08 pm
by apix
Posted: Tue Aug 08, 2017 6:21 am
Thanks. Unfortunately I'll need the model and associated datafiles to investigate any further.
Vensim is detecting 219 time points for some data parameters (possibly "TRA pass urban road charge[BE1]"). I'd need to check the data files to be sure.
Posted: Tue Aug 08, 2017 1:39 pm
Typically all the data has one long, common time vector, so if there's a long and/or irregular series, that will cause all the data to be reported differently from the model variables.
Posted: Wed Aug 09, 2017 1:37 pm
by apix
Thank you both, I will check the "TRA pass urban road charge[BE1]" serie.
