Changing FINAL TIME in a command file and other problems
billh
Post by billh »
I'm using command scripts (http://www.vensim.com/documentation/ind ... ?25670.htm) for the first time, and I've got two questions. The attached model shows what I mean.
First, the model is set up to run 144 hours--6 days. If you run that from Vensim, you can see "flow per hour" marking off each AM time. "marker" stays at 1.
If I run
"c:/Program Files (x86)/Vensim/vensim.exe" cft1.cmd
from Cygwin bash, where cft1.cmd looks like
SPECIAL>NOINTERACTION
SPECIAL>LOADMODEL|Changing FINAL TIME.mdl
SIMULATE>RUNNAME|extendfinaltime
MENU>RUN|O
MENU>VDF2CSV|extendfinaltime.vdf|extendfinaltime.CSV|extentfinaltime.lst|*
MENU>EXIT
I get Vensim to open a "Save backup as new file" file search box, with Save as type set to Vensim Models and the existing model name filled in. If I click Save, something happens, Vensim closes, and there's no apparent change to the directory.
What am I doing wrong?
Second, I tried cft2.cmd, instead:
SIMULATE>SETVAL|FINAL TIME=168
MENU>RUN|O
MENU>VDF2CSV|extendfinaltime.vdf|extendfinaltime.CSV|extentfinaltime.lst|*|0|168
MENU>EXIT
My intent was that the third line would change the End Time for this run, so graphs and tables would show results for 168 hours, and the next-to-the-last line would change FINAL TIME to 168, so the simulation would run that long.
This time, the same thing happens, and I also get a binary Changing FINAL TIME.3vm file in my directory.
What am I doing wrong here?
Thanks,
Bill
extendfinaltime.lst
(23 Bytes) Downloaded 291 times
(2.11 KiB) Downloaded 282 times
billh
Re: Changing FINAL TIME in a command file and other problems
Post by billh »
I found a typo that was generating the dialog box. This cft3.cmd is better, but it still doesn't change the time horizon:
MENU>RUN|O
MENU>VDF2CSV|extendfinaltime.vdf|extendfinaltime.CSV|extendfinaltime.lst|*||0|168
MENU>EXIT
Can you help me figure out how to extend the simulation and reporting time? In the final product, I'll be getting data of various lengths and needing to change the FINAL TIME and END TIME programmatically.
Bill
I've just run it, and FINAL Time is set correctly.
What do you see when you look at FINAL TIME using the table tool?
Could it be this?
billh
Post by billh »
I want the FINAL TIME to be 168, even though it's 144 in the model as saved to disk. I hoped that setting both the end time for reporting, as you indicated, and the FINAL TIME in the SETVAL to 168 would do that.
Here's the result I get, with the boring middle elided:
Time,flow per hour,marker
0,1,1
1,1,1
2,1,1
141,0,1
142,0,1
143,0,1
144,1,1
Did I understand your question properly?
billh
Post by billh »
More clearly, when you say FINAL TIME is set correctly when you run it, do you mean that it is 144 or 168?
billh
Post by billh »
I created cft4.cmd that has no exit command:
MENU>RUN|O
When I run it, it loads the model, and I get a Vensim window titled "Command Script Definition Errors":
sim  extendfinaltime
Executing SIMULATE>RUNNAME|extendfinaltime
Executing MENU>RUN|O
If I dismiss that window, I see a custom graph that runs to 168, as I hoped, the table tool shows FINAL TiME to be 168, and the End Time in the Control Panel Time Axis tab is 168. I can draw a graph with the graph tool, and it extends out to 168. Only FINAL TIME in Model > Settings is 144 still.
The directory now contains extendfinaltime.vdf and extendfinaltime.CSV, and extendfinaltime.CSV has rows running from time = 0 to time = 168.
When I switch back to cft3.cmd (the same file plus the MENU>EXIT command, I get the popup file dialog again. When I cancel out of that, I find it rewrote the CSV file but not the vdf file.
If I make the Run line
MENU>RUN|o
, it seems happy: I get both the vdf and the CSV, the CSV goes to 168, and I get no errors.
In summary (I think):
http://www.vensim.com/documentation/ind ... ?25670.htm uses "O", but my computer works only with "o".
The working command script is
MENU>RUN|o
MENU>EXIT
Bill
billh wrote:IThis time, the same thing happens, and I also get a binary Changing FINAL TIME.3vm file in my directory.
This is a backup file, you can ignore it.
billh wrote:My intent was that the third line would change the End Time for this run, so graphs and tables would show results for 168 hours, and the next-to-the-last line would change FINAL TIME to 168, so the simulation would run that long.
This is exactly what happens for me. If you look at the CSV file that is generated, time runs to 168. And looking at the values for final time using the table tool (not the equation editor), it's 168.
Are you expecting the value for FINAL time to be changed in the model itself? This is not how CMD scripts work, the script sets final time just for that one run, it does not modify the model in any way.
Your scripts are working fine for me. One note though, using NOINTERACTION can easily miss errors. If you have the CSV file open in Excel for example, the command to generate the CSV will fail, but the script continues to execute as NOINTERATION is set.
This is correct. The model is not modified in any way by the command script, the value for FINAL TIME=168 is only for that one run.
