I'm a beginner at modeling with Vensim and my question is about a fundamental concept. Attached you can find two images from Vensim help regarding the rework and errors. I have problem with workflow equation and do not know according to what equation my workflow graph can have the peaks after reaching zero. Your suggestion is highly appreciated.
Workflow equation in system with rework
- 2.jpg (35.06 KiB) Viewed 3027 times
- 1.jpg (33.63 KiB) Viewed 3027 times
Re: Workflow equation in system with rework
I don't understand what you are asking. Can you upload your model and try and explain what you need?
please find attached the rework model, and its outcome graphs. I tried to repeat the rework model sample which is in the vensim help, and then compare the outcome of my model with the rework sample. However, as you can see, graphs of my model (work flow and work remaining graph is not the same as vensim sample). I think that my equation for work flow rate is not correct. Could you please let me know how I can fix it?
- this work flow graph is not the same as the sample
- work flow graph.jpg (61.22 KiB) Viewed 3012 times
- rework model1.mdl
- (3.07 KiB) Downloaded 163 times
- the value of work remaining is negative after month 9, which shouldn't be correct
- equations&outputs.jpg (116.92 KiB) Viewed 3012 times
Is your equation different to the one in the Vensim sample model? You need to go through your work and check everything is identical to the Vensim model.ali wrote:Could you please let me know how I can fix it?
the vensim sample doesn't mention the "work flow" equation. so, I'm not sure my equation is correct or not, could you please let me know the correct equation for "work flow" variable in the vensim sample?
The model can be downloaded from
http://www.vensim.com/documentation/ind ... ?21495.htm
You will also find it on your hard drive under C:\Users\Public\Vensim\Help\Models\ModelGuide\3PROJ
I haven't looked at it for a while, but the model in the Help system contains what I consider to be a fairly basic error, which is also in your sample above.
The workflow equation is not constrained such that the workflow is less than or equal to the available work, so Work Remaining goes negative.
In the final Help system model, it's:
and your equation is:
In both cases, this should be amended to something like:
The MIN( ... , Work Remaining/TIME STEP) ensures that Work Remaining remains nonnegative.
work flow = IF THEN ELSE(project is done,0,Veteran Workforce*productivity)
work flow = 150*IF THEN ELSE(work remaining>0,1,0)
work flow = IF THEN ELSE(project is done,0,MIN(Veteran Workforce*productivity,Work Remaining/TIME STEP))
