Exporting via clipboard
I have a model with over 10,000 time steps and the conventional way of exporting variable entries via the Table tool doesn't work as the clipboard is limited to 8,000 entries. Is there a way around this other than using the more laborious 'export' process?
Re: Exporting via clipboard
No, that is the only other way unfortunately.
If you don't need every bit of data, you could set SAVEPER > TIME STEP.
