Market action
Posted: Thu Nov 23, 2017 3:40 pm
by paulvbaal
I am stuck trying to figure out how to get a market action to work.
I am basically trying to match supply and demand bids for a certain good, I have three entity types: Market, Supply, and Demand. Supply and demand entities have a auxiliaries "amount" and "quantity", denoting respectively the requested amount and the requested priority. The singular Market entity is the owner of the action and determines when to clear the market. However, when creating the action, I do not have access to the auxiliaries of refSupply or refDemand, even if the Collection in the market operator is set to respectively Supply[] or Demand[]. In contrast, with the Allocate action, set up in exactly the same way, I can access those, and it functions.
I attach my model to show the problem.
supply and demand.zip
(8.06 KiB) Downloaded 1359 times
Re: Market action
Posted: Thu Nov 23, 2017 3:42 pm
by paulvbaal
Sorry for the mistake, it should read that both Supply and Demand entities have an "amount" and "price" auxiliary, denoting respectively their amount and priority for the market clearing.
Re: Market action
Posted: Mon Nov 27, 2017 3:05 pm
We're back from the holiday and will take a look.
Re: Market action
Posted: Wed Nov 29, 2017 3:16 pm
There is indeed a bug. We're working on it.
Re: Market action
Posted: Thu Nov 30, 2017 1:28 pm
by davidc
We've identified the problem in the Market Action and will be releasing a fix before the end of the year. Thanks for pointing out this issue!
Re: Market action
Posted: Mon Jan 15, 2018 3:31 pm
If you email us at info at ventity.biz, we have a build that fixes this.
Re: Market action
Posted: Tue Sep 29, 2020 8:20 pm
by RWTH_FCN
I was wondering how can I use different allocation functions such as DEMAND/SUPPLY AT PRICE or FIND MARKET PRICE in Ventity?
Re: Market action
Posted: Tue Sep 29, 2020 8:54 pm
In Ventity, these are implemented as actions. They're in the Actions section under Defining Entity Types in the Help.
Re: Market action
Posted: Mon Oct 05, 2020 8:43 am
by RWTH_FCN
tomfid wrote: Tue Sep 29, 2020 8:54 pm In Ventity, these are implemented as actions. They're in the Actions section under Defining Entity Types in the Help.
Do you have any estimate when Market Price will be activated in the Action section?
Re: Market action
Posted: Mon Oct 05, 2020 4:51 pm
I'm pretty sure the market price already works.
Re: Market action
Posted: Mon Oct 05, 2020 4:55 pm
I'll find an example.
Re: Market action
Posted: Tue Oct 06, 2020 8:14 pm
Actually, you're right - it's still returning 0. I'll bump up the priority and see what ETA looks like.
Re: Market action
Posted: Tue Oct 06, 2020 10:01 pm
by RWTH_FCN
tomfid wrote: Tue Oct 06, 2020 8:14 pm Actually, you're right - it's still returning 0. I'll bump up the priority and see what ETA looks like.
In help section, it's mentioned that it is currently inoperative as well. Is there any hope for having it this year?
Re: Market action
Posted: Tue Oct 06, 2020 11:23 pm
Yes - but I'm also wondering if there's some way to reverse-engineer the value out of the results that are available now.
Re: Market action
Posted: Fri Oct 09, 2020 4:05 pm
Actually, the two-sided Market action does populate the clearing price. So, I think a workaround for now would be to use the two sided version, even if the supply or demand side only has one entity.
Re: Market action
Posted: Sat Oct 10, 2020 11:16 pm
by RWTH_FCN
tomfid wrote: Fri Oct 09, 2020 4:05 pm Actually, the two-sided Market action does populate the clearing price. So, I think a workaround for now would be to use the two sided version, even if the supply or demand side only has one entity.
What about one sided action? Does it support Market with one demander and several suppliers?
Re: Market action
Posted: Sun Oct 11, 2020 12:32 am
Yes - that should work. It'll just be processing a collection of 1 entity on one side of the market. I'll see if I can come up with an example.
Re: Market action
Posted: Mon Oct 12, 2020 4:24 pm
by RWTH_FCN
tomfid wrote: Sun Oct 11, 2020 12:32 am Yes - that should work. It'll just be processing a collection of 1 entity on one side of the market. I'll see if I can come up with an example.
That would be great. The examples in this link might be useful for designing a one to many allocation:
viewtopic.php?f=2&t=7034
